stripped threads for tranny oil drain
b3200user
,fel,mower, rear snowblower,brush hog
Apr 26, 2018
upstate ny
Need help, B3200 owner : If the threads on the casing ( not the drain plug it self ) where you screw out your oil drain plug to drain the oil out of the tranny are stripped, what can be done too fix the problem, with out having to change out the whole casing. New to forum, all help appreciated.
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
441
42
Atascadero
The case could have a Heli-Coil put in or drilled and tapped to the next size plug. Where people make mistakes is they over tighten drain plugs in soft metal cases (Aluminum). Not saying it was your fault.
7,824
Either a Heli-Coil or tap it out for a plug a size larger. ;)
