starts but wont run
jonny5757
1998 kubota
Jan 24, 2025
hemet ca.
my kubota starts but wont run, good battery,new fuel filter, new air filter,new stop solenoid new fuel filter. it was running fine and then it died, i started it back up fine, next day same thing but it happened twice,3rd day it did it a few times,and now it starts but wont run.
5,275
well you'll have to post WHICH tractor you have. Can't offer what is causing the problem until I have a look at the wiring diagram.
Obvious things are 'user upgrades ' to electrical, vermin chewing wires, loose connectors, bad battery cables, corroded wires, gimpy switches(seat,PTO, PBrake, ?? )
5,661
Your profile says 1998 Kubota, but nothing else.
If you told us what Kubota you're working with, it would be helpful.
Is it a tractor, excavator, UTV, skid steer?????
What model?
Starts but doesn't run - - does it shut down when releasing the key?
mendonsy
B7500HST/LA302
May 28, 2012
352
31
Mendon, NY
Sounds like there might be some crud in the fuel tank. Check the fuel line from the tank to the filter to see if you have full flow.
1,500
Guessing that is the type of run/stop solenoid that needs power to let tractor run. Getting that power from the key switch in the start position so it starts. Release key to run position and power is cut to solenoid and tractor dies.
I recall reading about the solution in this forum but no recall on the solution.
