Starting Kubota M105X
nschlief14
Kubota M105X
Nov 1, 2022
We have a Kubota M105X. Doesn't want to start after it has been running, and you shut it off. Try to restart and it just clicks. If the tractor hasn't ran for a few hours or overnight, it will start fine most of the time. I have twisted on the positive cable when it doesn't start, and sometimes it then starts. So I assumed it was the positive battery cable, purchased a new one from Kubota and installed it. Yesterday it started fine the first time, ran it for a while and will only click and not start. Then this morning, it sat overnight, started fine. Ran for awhile and warmed it up. Shut it off and now it starts again. Did this a second time and it started right up. This is an intermittent problem that happens on and off again. Last week I had ran it for a while, moved some round bales, shut it off and tried to restart it and it would not start. Twisted on the positive bat cable and still only click, no start. Let it sit overnight, and then it started just fine. Could the starter solenoid work like this, when it gets warm, it will not engage??
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
Start by making sure you have a known good battery. A load test may be in order though that's probably not it if cold starts are good. If twisting a battery cable makes it work try disconnecting both battery cables. Clean battery posts and inside the cable connectors. Replace on the battery tightening firmly. If you can move them they're too loose. Follow the ground lead to the frame. Clean and tighten there. Some tractors do not get enough power to the low current side of the solenoid. Owners sometimes add a relay (controlled by the starter switch) to get a higher current power source to the solenoid. You could monitor the solenoid voltage with a meter to see how much voltage it gets.
nschlief14
Kubota M105X
Nov 1, 2022
I had the battery tested at work as I work at John Deere dealership. We load tested it when this started happening and the battery is good. That is what lead me to the pos battery cable. We will tighten the connectors and also check the ground to the frame again. Thanks for your help.
