D DoorsPls New member Equipment B330su May 30, 2014 1 0 0 Kansas City, Kansas May 30, 2014 #1 Can someone help me? ok, im sitting in the tractor seat.....how do I start this thing? The only tractor I have operated is a 1946 Ford 601...Grandpa cant make it out to the barn and i dont want to ask. Thank you.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 31,013 6,993 113 Sandpoint, ID May 31, 2014 #2 Push in the clutch pedal on left, turn the key to the right and it should start if everything is right.
gpreuss New member Lifetime Member Equipment L3200DT w/FEL, K650 Backhoe, 5' Rotary, 40" Howard Rotavator, 6' Rhino blade Oct 9, 2011 1,166 6 0 Spokane, WA Jun 1, 2014 #3 PTO lever needs to be OFF. Drive control pedals on the right need to be at center neutral position.
