Stalling problems
OlFerguson
4440, 1120D
Jun 1, 2017
192
11
My brand new 1120D for some reason occasionally will get bogged down and just stall out. I tried restarting it after it stalled out and it wouldn't turn over so I let it sit and continued fencing and tried again later and it fired up with no hesitation. I have checked fuel lines, air filters and potential areas that could cause it to stall out and everything seems fine. It has 72 hours on it but this isn't the first time it has done this. Every part on it is OEM, no mods still under warranty. Any ideas?
6,633
1120D ????? :confused:
Is it a Kubota?
Full model # Including any letters before the # please. ;)
2,583
Gonna guess : one of these????
http://www.kubota.com/product/UtilityVehicles/RTVX1120.aspx
check for obstructions in the fuel tank - change the fuel filters too.
AND IF still under the warranty - have the local dealer look at it.
OlFerguson
4440, 1120D
Jun 1, 2017
192
11
Yep that is it! I have the camo/real tree body finish. I will try bleeding the lines and changing the filters. I usually change all filters when seasons change winter/summer and change oil at 250 hours. I wish the dealer wasn't 3 hours 1 way
6,633
AWWWWW... OOPS... I was in Tractor mode! :p
Vent issue?
Fuel supply restriction?
rjcorazza
Mar 9, 2016
778
24
Hyattstown, MD
"I tried restarting it after it stalled out and it wouldn't turn over..."
If you mean that the starter does not crank the engine over, then there are other problems. Other than the won't turn over comment, it does sound fuel related.
3,457
You might want to check your gounds, if as you say it wont turn over meaning the starter wont turn, also maybe check your air filter, critters have a way of finding places to store stuff where it shouldnt be,, and after that,, you should be calling your dealer !!!!
