Splitting a B20
3AMranch
Wenatchee, WA
I’m new to tractors. I inherited a B20.
It’s in fare condition. I believe I’m going to need to split it, do to a leak from the main hydraulic reservoir. Aside from the seal, is there any surprises I should watch for? The rest of the tractor seems solid, no leaks other than the reservoir. And I am happy to take any advice. Finding a parts list would be great.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Full illustrated parts listing here
https://apps.kubotausa.com/illustrated-parts/
I don't think there's a service manual for that model anywhere on the net for download unfortunately. Does it have a separate tank, or just use the transmission? North Idaho Wolfman may know of a similar base model tractor that it shares some components, and/or he may have a manual for one or the other. Shoot him a message and see if he can help.
3AMranch
Wenatchee, WA
It has a shared tank with the Transmission. Hydro-static. Good start thank You!
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Just had a quick look at the aussie site, it appears it uses part of the frame or subframe for the reservoir, or does it just run a pipe through? Where is you leak exactly?
6,926
Where is the leak at?
Depending on where it's leaking you might or might not need to split it. ;)
3AMranch
Wenatchee, WA
Sorry it took me so long to get pictures.
I believe the leake is from the front bottom of the reservoir. I ran the tractor for 5 hours yesterday and had to add three quarters of fluid.
