coachgeo
Slowwwwwly am converting an oil stove chimney into my wood stove chimney. First I thought this chimney had no clean out. Wierd...... then in deconstruction of the "convert to closet" that was done around the former area this oil stove stood I discovered the clean out was below the floor in this pier and beam home. Below the floor and with NO CLEAN OUT DOOR.
Anyway... from that point I started cleaning the chimney that had never been cleaned. About a gallon of soot poofed out as I probed from the bottom up. Then maybe two gallons avalanched down out the opening followed by the mother of all avalanches of another 4 or five gallons of soot.
so then soot dust was all over the house and a good 8 gallons or so is under the house. We mostly cleaned up the soot dust that puffed into the house turning everything black in the house as best we could BUT every time I work on the trap door/hearth non combustible floor area covering the spot where the wood stove will be I get soot puffed up into the house again. Thank good not as much as first time..... but enough to where the white kitchen floor is now GREY and Im about to use a carpet clean machine the hard floor AGAIN. (just 30+yr sealed junk floor..... no carpet or anything yet)
Sooo....... any chemist or pragmatist have an idea of how I can convert this soot to clumps for removal from under the floor.
Also any ideas on disposing of it in a recyclable way..... like is there any uses for it OUTSIDE. I live on dirt/gravel road. Does it make good weed killer, Rodent deterrent (moles, ground hogs, etc.) orr??
