Snowsport front blade adapted :-)
sdk1968
B2601HSD & CK4010HST 4WD/FEL
Oct 19, 2016
929
44
from my other threads... my Kubo came with a snow blower on a hydraulic mount which is pretty cool & hope to use it with enough snow.
BUT most times we dont get that much snow here at my place... snow ive been using a snowsport "squeegee" blade on my zero turn for several years in the winter.
they work pretty good as long as no one has driven on the snow first. :)
they also work decent on sand & pushing briars around if you lock it into place.
so figured would mount it on the front of the Kubo & have a couple of options.
turns out that dropping the snowblower off & leaving the mount meant that all i had to do was get a pivot bolt thru the rear of the mount & then mill down some of my hitch on the plow. BINGO! instant hydro front blade!
or as some might call it: a BUBBA BLADE.
so heres some pix, laugh if you want or maybe even give it a shot.
