I had to look for a picture of your tractor to make my determination, and I believe that the front frame of your tractor might accommodate the hitch that was used on the BX2670. The BX2670 front frame is rectangular in shape like your tractor however I am not certain of the size of the front of your frame. If you post the dimensions, I can compare them with my BX23S which shares the same basic frame as the BX2670. You might have to have a custom driveshaft length made to accommodate the drive mechanism.
Nope! Measure the front frame dimensions. Height and length and will compare it to my BX23S. If yours is close to mine it will work if not it is a no go.
