Snow pusher
989dl
Bx2680
Nov 14, 2020
Houghton lake mi
I purchased a hla 1500 snow pusher with the quick attach for a bx2680 the quick attach was not attached to the pusher there are 3 different sets of mounting holes for the angle what are the proper mounting holes for that pusher for that tractor
pokey1416
Jun 24, 2020
564
835
SW Michigan
Watch this video from Good Works Tractor it might help.
pokey1416
Jun 24, 2020
564
835
SW Michigan
I don't know yet as my pusher (HLA) has not arrived yet. I'm assuming it is the angle of attack with your curl/dump function? Maybe someone else that has one can chime in.
Thunder chicken
M7060
Dec 29, 2019
295
120
Northern ontario
if it’s a bracket you got to mount on the pusher yourself,....... mount the bracket onto your loader’s QA. Drive up to the snow pusher and the holes on which to mount it should be obvious! Or drill new ones! :)
989dl
Bx2680
Nov 14, 2020
Houghton lake mi
I think I’m going to try the 90 degree angle to start with. I may have to change the angle if I install the the back drag kit on it 🧐
