Slip Clutch assy for LandPride 1860 rotary cutter
pinkerpv
3800, rtv1140CPX
Jul 13, 2016
34
MADISON, ALABAMA, USA
I have an 1860 LandPride rotary cutter with the slip clutch assy for the power takeoff drive shaft. Over the years the assy has worn and now the clutch assy wobbles and causes the drive shaft to wobble. I want to buy just the part of the assy that is worn but it costs $350+. A new clutch assy is $450; however I have found an aftermarket assy that should fit for $200+. The part i need is a solid cast part machined for the gearbox shaft. It has a hole thru it for the bolt to hold the assy to the shaft.
My question is does anyone know of a salvage yard for tractors and specifically Landpride equipment. I have found a few on the webb but no parts for me.
