I recently bought my first tractor a (Z)B1600 with a couple of problems.
The hand throttle lever is siezed solid (foot throttle works fine). The tractor didn't come with any manuals and so far I haven't been able to find any online for dload or purchase (I'm in the UK).
This shows the problem part, viewed from the engine bay:
So far I have drenched it all in WD40 and then knocked it about a bit with a large hammer The nuts and washers (marked with green x) at the bottom came off easily. The bit marked with blue x which should rotate does not do so but I managed to move it down the shaft by giving it a couple of solid knocks from above with the end of a bar. All the bits above, (marked with pink x) do not move at all. My next step was to try and remove the two pins (marked with red x) but they do not seem to be allen bolts as I first thought.
Does anyone know if they are just friction fitted pins? Am I safe to drill them out? Will this even help solve the siezed hand throttle lever?
Not having any manual (or experience) I would appreciate advice from anyone.
Once this is fixed I have an oil leak from the bottom of where the pto exits the tractor, but I'll save that for another post
