Sickle Bar vertical bush triming?
coachgeo
Nov 16, 2012
2,459
37
Southern OH
can a sickle mower be run in the vertical position to trim bushes? My drive has about 8 feet tall bush on both sides. A good 1000yds of it.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
A belt driven type probably could be but you would have to modify the blade to be held straight up. I have seen several different one that are boom mounted, hydraulic driven but they are pretty expensive. Might look at the VMC brand. I have a boom flail mower and have been very pleased.
bcp
BX2360
Apr 20, 2011
644
79
SW WA
If it has a pittman arm, usually a wooden bar about 2 feet long that drives the cutters, even if belt driven it won't cut if raised or lowered much from horizontal.
The end of the arm would be going left-right-left-right while the cutter would be trying to go up-down-up-down. :)
Bruce
Bulldog
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Don't remember the model number but we had a IH sickle that was belt driven (no pittman arm) that would cut at any angle. I found a picture of a VMC mower that was mounted on the FEL but I can't find any info about it. You might contact them directly and get something though.
olthumpa
L275
May 25, 2011
1,501
Maine
In the winter I volunteer to groom snowmobile trails. One of the constant chores is cutting the branches and brush on the side of the trails. We use a setup very similar to the pic below. It is hydraulic raised and driven capable of cutting 2 1/2 inch branches.
This is where it was purchased - I do not know what they paid for it but it works great.:)
http://www.mountaingrooming.com/
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Coach, an IH 100? or AC 80 or 82 have balanced head gearboxes, that will cut at any angle. Also hydraulic driven Haban, Triumph and others. There are other brands that have either hyd drive or balanced heads. I just have experience with the ones mentioned. Sorry, no pics...:D
Tooljunkie
May 13, 2014
4,150
Imagine taking the whole apparatus and turning it 90 degrees.if its custom fabrication for a specific use,it can be done. If we can make one run under water for weeds, and drive it with a electric motor above water with a long belt, the possibilities are endless. image.jpg
Cant get anymore redneck than that...
