Seat switch
Swando
Kubota L3301 tractor
Mar 3, 2017
35
Fairfield, Idaho
I bought a used L 3301 and the switch under the seat doesn't seem to do anything. Isn't it made to turn off PTO when operator leaves the seat?
mdhughes
L3901DT
Dec 10, 2014
1,225
654
Ste Geneveive county, MO
When you get off the seat it should kill the engine in about 5 second. If you flip the seat up before the 5 seconds it will keep running. If it doesn't kill the engine after 5 seconds I would say that the tab on the seat has been bent and needs to be adjusted. This is covered in the Operator's manual.
Swando
Mar 3, 2017
35
Fairfield, Idaho
I bent the seat tab in towards the seat cushion. Now engine will shut off if you get off seat while moving or if PTO is engaged. If you move around on the seat engine will cut out. But I want the safety working.
