Seat switch bypass
Bobby Bee
Connecticut
Hi, brand new member here and just joined this site. I just purchased a B2601 with loader and backhoe. Expecting delivery in next day or two. When I mentioned to the salesman about wanting to buy a 3 point wood chipper, he told me I would have to either put a heavy item in the seat to “fool” the seat safety switch or bypass the switch electrically. I have read in a operators manual that I downloaded (2014 version) that there is a procedure to follow in order to disengage/bypass the seat switch when you want to use the PTO in stationary mode with the operators seat unoccupied. Is there a way to engage the rear PTO and use a wood chipper without altering the seat switch? It seems silly to me that Kubota would not make allowances for this. Thanks
GibbyESS9
2020 Bx23s,BX2672 plow, Titan Forks, Land Pride 48” BB, FEL, Bestco Flail mower
Sep 30, 2020
106
137
Blue Point NY / Newfoundland PA
Not sure on that model but my BX23S I have to lift the seat up, not spin it then the rear pro works for my chipper. I guess that keeps the safety switch engaged. Someone on here will know. Welcome
J
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,097
1,097
E.
as soon as you lift your arse off the seat tilt the seat towards the steering wheel and your pto should continue to operate. If tyou wait more than a second or so to tip seat forward the engine would shut off.
My B26 worked that way but my pto was not electric over hydraulic I had to push clutch in then throw a lever. Not sure if the electric is different seat function.
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
385
295
NH
On my L I tilt the seat forward first then engage the PTO
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,419
622
Richmond, Virginia
Yeah... it seems if you start the tractor, engage the PTO while sitting, you have a few seconds after standing to unlatch and flip the seat forward. There are two switches. One is the 'operator presence' switch which shuts the tractor off if you leave the seat (like if you crashed and were tossed off) The second switch, tells the tractor no one is supposed to be on the seat as it is unlatched and tilted, a deliberate reason for 'no operator'. Makes sense.
However (always is) I think it is a touch risky to quickly stand up, unlatch the seat, flip it and then get off. I'm old and clumsy. So... I start my tractor. parking brakes set. Get off. Unlatch tilt the seat.Standing along side the machine, I move the PTO lever to 'Rear' then engage the PTO.
Trustable
l2501HST
Jul 5, 2022
394
405
Your seat should flip forward towards the steering wheel. Engage the PTO, rev it up to your speed, then quickly get up and flip the seat. If it’s real windy you may want to get a strap or bungee cord to help it stay flipped, as it’s pretty easy for a moderate gust to flip it back down and then the tractor shuts off.
aaluck
Oct 9, 2019
995
842
Snowdoun, AL
Okay. Will this work with my L4400HST? If so, it would eliminate a lot of frustration when spraying. Right now I have to get someone to sit there while I spray flower beds, etc.
Trustable
l2501HST
Jul 5, 2022
394
405
It should. Based on what I’ve read on here it seems to be universal on Kubota models that don’t have a button to keep it enabled.
imarobot
Apr 18, 2025
385
295
NH
I would try flipping it up first then engaging the pto. If that works, it's a lot easier than trying to get the seat tilted before it stalls out.
I don't know, maybe your tractor is different than mine, but this works on mine. However, if I have the mid-pto engaged it will stall even with the seat tilted up. I did some head scratching the first time this happened.
GibbyESS9
Sep 30, 2020
106
137
That’s what I do with my chipper. Get off. Lift seat up/forward then engage pto at low rpm setting then increase rpm .
works every time. Good luck
J
nbryan
Jan 3, 2019
1,411
932
Hadashville, Manitoba, Canada
With my B2650HSD, engage the parking brake, shift the transmission to neutral, and then you can activate the rear PTO while off the seat. From my manual:
"Stationary PTO
To park the tractor and use the PTO system (for chipper or pump, for example), start the PTO system in the following steps.
1. Apply the parking brake and place blocks at the tires.
2. Make sure the shift levers are at NEUTRAL, and start the engine.
3. Set the PTO select lever to rear only position. [B2650/
B3350 only]
4. Set the PTO clutch lever to engage "ON".
5. Set the engine speed to provide recommended rear PTO speed.
6. Get off the tractor."
Donystoy
Dec 10, 2013
718
357
Binbrook, Ontario
On my LX2610 it has a button on the dash that I press until it lights up. Then I can get off the seat and keep the pto running. I would think that other models would be similar.
John T
2017 BX23S
May 5, 2017
1,260
795
under a rock
Soon after I bought my BX23S I disconnected the seat switch.
I distinctly remember getting a rash of sh*t from the safety police on this forum.... :rolleyes:
In any case, I figured it out on my own and I'm still alive and kicking...
If I remember right, There were 2 plugs under the seat ( don't hold me to that.. may be only 1)
Anyway I simply unplugged them..... and it disabled it.
For me it's nice to get off the tractor without disengaging the mower blades.
not sure if it effects the backhoe operation.... I disconnected the seat before I ever used it.
5,301
Your sales man is a jerk,, lift the seat up put the PTO lever in the rear PTO spot engage the PTO and chip away. NOW and this is only MHO, never disconnect the seat switch unless it is for testing, while safety switches are a royal PIA sometimes they are there for a reason, and most of those reasons have been written in blood
