seat safety switch issue
lumbertown
Kubota L3130
Jun 14, 2020
Muskegon MI
We have an L3130 that is having an issue with the seat safety switch. I have been desperately trying to locate a schematic that shows the wiring on this tractor. I have not been able to locate the relay (if there is one) that is tripped by the safety switch. Currently the tractor starts with no problem but even when someone is sitting in the seat it clicks and shuts off like the seat is not occupied. When you put the seat forward and push the lever down, it clicks and then it does a second click and all shuts off. I am wondering if it is a defective safety switch or what is clicking under the hood.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
Welcome to the forums!
Which model do you have?
L3130F: 2WD
L3130DT: 4WD 8 speed
L3130GST: 4WD 12 speed
L3130HST: 4WD hydro
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
I have an L2501. I solved my seat switch issue by flipping the seat up and noticing the rod on which it flips up was only connected at one end. the other end had slipped out of its hole allowing too much seat movement. A flat washer and a small cotter pin fixed the problem. Check for the dumb stuff first.
