Screwing in a 90 degree zerk fitting in a tight spot
CompostMaker
Kubota l series
Nov 2, 2020
Oregon
Hi folks,
I’ve got a kubota l series tractor and a 90 degree zerk fitting fell off my loader arm and I’m trying to get it back on. It’s in a tight spot and I don’t have any room to screw it back in. Can’t use a ratchet because of the 90 degree zerk. I’ve tried raising and lower the bucket arm and no position gives me enough access. Any suggestions?? Is there a special tool I need?
SidecarFlip
Banned
557
Almost always an angled Zerk will be a 2 piece Zerk. The body and the fitting separate. Clamp the body in a vise or a pair of Vice grips and use a socket to unscrew the top fitting. Screw the body back into the hole and screw on the fitting.
SDT
multiple and various
Apr 15, 2018
3,256
1,055
SE, IN
Hi folks,
I usually use a suitable sized open-end or combination wrench.
SDT
6feettogo
B2650
Apr 22, 2020
86
58
Newman Lake, Wa
Hi folks,
I hear you. I took mine off the other day (LA534 loader) to put on grease zerk caps. I ended up using a needle nose plier to get the zerk in front of the hole. I then used my index finger of my left hand to hold it there and then used a wrench to start turning it and it started.
armylifer
Mar 26, 2013
2,098
843
Thurston County, WA
I did not know that about angled zerks. Thanks for that tidbit. I have had success using a needle nose pliars but next time I need to replace a 90 degree zerk I will try your method. Is that true for the 45 degree zerks too?
