Run Away Engine
David Ward
L 2800 w/Back Hoe
Feb 9, 2015
Salem, VA
I had the fuel line freeze up recently waited until the weather got al little warmer. changed the fuel filter and replace all the old fuel. Still could not get fuel to the injectors. Removed the fuel pump seemed OK tried to remove the injector fuel pump but could not get it all the way out. Had trouble getting it back in place but finally manged to do that. Put everything back got fuel to all injectors tightened down everything and now it starts after a couple of tries but then engine rives up and key will not shut off tractor. I have to pull the fuel line off the fuel pump to shut off. Any help would be greatly appreciated. this is a 2010 Kubota 2800 it has less than 300 hours on it.
Thanks,
Dave Ward
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Thanks,
Dave Ward
While I don't have experience with this exact tractor, what might have happened is you stretched or disconnected the governor spring. Wolfman will probably be along to narrow it down for you. Welcome to the forum...:D
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum from Alabama. Can't help with this but you are not the only one with this problem.
11,512
Dyidave nailed it,
When you tried to pull the injection pump you probably streached /lost/ or otherwise damaged springs and also have the linkage and rack for the injection pump in wrong.
You need to get the WSM for your tractor and remove the pump evaluate the damage and replace the damaged or dislocated parts and then reassemble it properly.
P/N 97897-13190 $91.09
And no there is not a free download file available.
http://www.colemanequip.com/parts/KubotaParts/97897-13190/277
