RTV900 Fuel Gauge erratic
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
My fuel gauge shows full when sitting still. The tank is about 1/2 full. When i am moving it moves around between 3/4 and full.
Any ideas if it is the gauge, float, sending unit......?????
Thanks
4,221
Yep. That’s what it is.
(More seriously,… it’s more than likely corroded or loose connections in the gauge circuit. First thing to check is a good-ground at the sending unit.
Workerbee
Zd21
Mar 1, 2020
380
258
MN
His ground is obviously good or itd be reading empty. The sending unit works by completing the circuit to ground. More likely your problem is that your sending wire from gauge to tank is grounding out somewhere. Then while running that spot on the wire is vibrating on and then off from the ground.
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
thanks i will check it
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
4,221
That’s correct on most analog gauges.. Thanks for that.. Some digital gauges will “drift” erratically if the ground is poor (corroded).
TTFO… Workerbee makes a good suggestion by implication… if you ground the wire at the sensor completely the gauge should read ”Full” if the wire is intact and the gauge is healthy.
