L LenPA New member Equipment l3901 Jan 2, 2022 27 2 3 Sayre,Pennsylvania,USA Jan 7, 2023 #1 Looking for a heater for my cab on a new RTV 1120. I am looking at a 12V plug in dash mount 15 amp draw. Any suggestions? Thanks.
A animals45 Active member Equipment L3301l Apr 22, 2021 269 84 28 Mabie CA Jan 7, 2023 #2 What ever you get make sure that it can be aimed to use as a defroster . Them Cabs get wet windows inside real quick in wet weather . animal
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 30,197 6,367 113 Sandpoint, ID Jan 7, 2023 #3 I don't know of any 15 amp Plug in heaters that are worth the money. Most of the efficient electric heaters, need 25 to 30 amps to work. Reactions: 1 user
ve9aa Well-known member Equipment TG1860, BX2380 -backblade, bx2830 snowblower, fel, weight box,pallet forks,etc Apr 11, 2021 1,202 982 113 NB, Canada Jan 7, 2023 #4 12volts x 15amps = 180watts It'll do ALMOST nothing in cold weather. Reactions: 1 user
B BX'r Member Equipment BX2370 Jun 13, 2020 78 17 8 ipsc Jan 8, 2023 #5 I have this one for sale, good heater but my bx only has a 40 amp alternator. Heater Dimensions: 6”x 5” X 4” 12 Volt, 50 Amps, 600 Watts 10,020 BTU’s Brushless 50,000 Hour Ball Bearing Fan 10,000 Hour DC Thermal ©RuCar Vacuum Sealed Elements. Case Construction: T5052 Aircraft Aluminum. Wired Entirely with GXL Wire Thermally Protected HIGH, OFF and LOW setting Last edited: Jan 8, 2023
