If you can recall what you did 5.5 years ago, it will be appreciated. Guess we got lucky with our 2009 rtv 1100. It ran 600 hours and recently the original pump failed. I'm looking into bypassing it with an electric pump from Summit Racing that has specs close to the one that you posted a link to, and I have a couple of questions: (1) do you recall where you mounted it? There is limited space and even if I found a location it will be next to impossible to drill holes for the mounting bracked. (2) my electric wiring skills are limited so if you can advise on how to install a fuse and relay, it would be helpful!
