Rtv xg850 wont shift out of neutral
smaynard
Kubota rtv-xg850
Jun 24, 2025
Phoenix Az
So the brake switch it working properly just changed the neutral safety cable isn't seized or stretched. Still wont shift out of neutral. Any ideas?
3,362
That brake shift cable should have almost ZERO “play”….such that stepping on the brake operates the hydraulic-shift-release so as to allow gear-shift.
My X900 was improperly adjusted and had “slop” just forward of the firewall where the cable ”housing” or “sheath” would slip and slide allowing “slop” in the action. Gettting rid of that slop made the RTV much easier to shift gears.
