Hi Everyone
First id like to say thanks for your time in reading my post. I have been having issues with the idle and starting of my X900 I need to have my foot on the gas to get it to start and constantly on the gas to keep it running. To switch from Neutral to a gear I've been raving it a bit then as it dies down timing it to put it in gear and again stepping on the gas peddle I am assuming this is a fuel filter issue or idle screw/ throttle cable gas pedal linkage. I've checked the air filter but being i have no dealership within a days travel i have not been able to bring it in for a service, or even get a fuel filter so I figured i check hear first to see if there are any recommendations that I should try or check before traveling to get the parts. Prior to this the machine was not used for 4 months and 2 weeks before the muffler broke and I had it welded back together. Any advice be appreciated thanks
