Hd883chopper
2006 Kubota L4330 w/ FEL - Kubota Zero Turn ZD21 - 2010 Kubota RTV900X
Hi folks,
Just wondering what the more experienced tractor operators would say here. I was plowing today with my L4330 4x4 w/ FEL and at I had it idled up to about 2400 RPM’s. Once plowing and working it would drop to about 2200 RPM’s.
My foot pretty much had the floor pedal mashed 90% of the time. This is about as hard as I work this machine but she was definitely working.
Here are my questions, should I be idled higher so I’m not flooring the pedal as much? In other words, does it matter if I’ve got the pedal pegged to the floor or should I just give the engine more power?
What is the ideal RPM range when plowing, tilling or any other heavy work?
I can hear the hydrostatic transmission whining a little under this load. Is this normal? I’m always concerned that I’m stressing the hydraulics and will damage something. Since I’m not operating the PTO with this scenario, I know it’s all transmission stress.
Thank you,
HD
Thank you,
HD
