First time using a rotary tiller. I assume I put the 3 point down in float position and let the skids determine the depth? Can’t find any info on this anywhere. Even the manual doesn’t offer any advice.
That'll work. Also, most tillers have adjustable skids so you can vary that tilling depth from it's minimum to maximum tilling capacity. If yours does, you should be able to loosen a couple of bolts at the ends of the skids to adjust them. One end would be a pivot and the other should either slide up or down or may have independent adjusting holes.First time using a rotary tiller. I assume I put the 3 point down in float position and let the skids determine the depth? Can’t find any info on this anywhere. Even the manual doesn’t offer any advice.
