ROPS lights
3,449
I have a question, yeah I know OMG not again,,, Anyways I am wondering if anybody has problems with the ROPS mounted lights shaking all over the place. Seems when i run mine I get seasick the way the light bounce all over. I tried pieces of rubber under the mounts and carpet nada same same. Anybody have an idea?
tcrote5516
BX1860, FEL, 50" Front Blower, Heated Cab, 6' blade, 3pt carry all, 3pt hitch
Sep 2, 2014
482
Southern New Hampshire
When I had mine mounted to my ROPS I never had that problem (have them on the cab now and that's solid). The ROPS cant be to blame for the movement as they really just vibrate. If your seeing actual movement it must be those small vibrations magnified by a less then solid mounting hardware setup on the lights themselves. I would not involve rubber at all and try to get the most rigid setup you can find. Anyway to gusset that up a bit?
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,381
385
Mine are mounted rigid and they don't move or flicker?
I just switched to a 180W LED light bar facing forward and an 80W LED flood facing backwards.
Only annoyance I have now is they have so much light they light me up too. I pretty much have light 360* around the tractor now.
3,449
I guess Im going to have to brake down and buy a LED light bar
CDNBX25D
BX25D, Bro-tech wheel spacers/skid plate, Ken's bolt-on hooks, LED light bars
May 24, 2015
12
Saskatchewan
I don't have the need to fold my ROPS, but I still can with the lights mounted on top.
bmblank
Mar 4, 2015
667
296
Cadillac, MI
Skeets, do you have floods or spot lights? The angle of the beam would have alot to do with how noticeable movement is. If the lights move 5 degrees on a 30 degree spot light it should be alot more noticeable than on a 60 degree flood.
3,449
Good point I had not thought of that! They are 75w halogen driving lights, and i guess I made the rash assumption they were floods,, they might be spots:confused:
Grouse Feathers
Feb 16, 2015
1,022
10
Lovells, Mi
Wow those driving lights must be great on your souped up BX cutting the grass at 60 mph. You can probably pick out those grass blades at 100 yards and pick a line to slide a four wheel drift around that apple tree a quarter mile away.:rolleyes::rolleyes::rolleyes: You grass cutters are all about high speed performance. I just blow snow and grade the driveway at 3mph, and that's 4.4 feet per second. Flood lights that light up the woods for 50 feet give me over ten seconds to avoid the shiftiest tree trunk, even at my advanced age and slowing reflexes.;););) With some guys you got to take the shot when its presented.:D:D:D
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
skeets,, it's not the lights that are moving, it's your eyeballs. you need to tighten the nuts on your eyeball sockets. I think the torque is only 4 inch lbs.(G)
3,449
Im sure theres a couple of loose nuts there some place ;)
And the price was right on the lights,, FREE :)
