ROPS hole?
Kubota Dave
B2650 HSD, B7800
Jul 31, 2016
23
What is the threaded hole for on the rops? It's right where they hinge.
Looks like a way to stop them from shaking back and forth anyone know what size bolt it takes?
1970cs
1,124
Grand Ledge
You are correct! They used to have a knob and screw combo that would take up the slop in the two halves.
You can use a bolt or I believe that ZD, BX and some of the older B series had the knobs.
Pat
Kubota Dave
B2650 HSD, B7800
Jul 31, 2016
23
Pat
Really? Wonder why they stopped doing it. The robs drive me crazy after a hour or so!
Ike
Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20
Jul 18, 2015
324
Mich
I have an L 3301 and it also has the bolt in it. It has a bolt with a lock nut on it. The hole in the ROP has a nut welded to it. The head on this bolt has a head the size of a 3/8 bolt so whatever the metric size would be . Hope that helps you
