Replacment engine needed for a L3710
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Finding a used engine block for a 3710 might be as rare as hens teeth. The tractor was built from 98-02. And being that the tractor is only 10 years old there may not be many of them in junk yards to pick parts from. I'd say check with West Kentucky Tractor and see if they have a 3710 in their yard or see what motor might be interchangeable with the 3710.
www.wkytp.com
hodge
Nov 19, 2010
2,905
453
Love, VA
It also might be worth finding out what other equipment shares that engine. My skidsteer has a V1702 Kubota engine in it.
RDR
M5400,B6100E,K008,L175,TG1860Diesel,JD355D,3)Leyland 154D's,YM2000,IH1466
Oct 13, 2009
147
Danevang, Tx.
Two things I've seen that are hard to get around replacing an engine in a Kubota tractor. Most use the engine as the frame to attach the front axle, radiator, etc. There also has to be the hydraulic pump drive at the injection pump.
The plate that bolts to the engine for the bellhousing is the same bolt pattern from a Z751 to a V2203. The center hole is bigger for the rear main seal cover on the V1903 and V2203. The V1501 in my L345 had the same measurements on length and height as the V1903/2203. It had the smaller rear main seal cover.
How do I know all of this? The L345 was so worn out when I bought it, you had to tow it to start it. It had more blowby than exhaust when cranking it with the starter. I bought a V2203 parts engine to experiment with. If the head wasn't cracked I would have used it in the tractor. I bought a V1903 in Pa. on Ebay. I picked it up on a trip to Upstate N.Y. It didn't have the holes to mount the front axle on the tractor.
I had a feeling I needed at least one piston for the V1501. It needed two. I have a Z751 I got for $50. It is 1/2 of the V1501. I used the pistons, bought some Kubota gold plated rings for $307 and fixed the V1501.
From what I have seen searching, the V2203 is more available. If it has the holes for the front axle and hydraulic pump drive, it should be a bolt in replacement. I don't know if direct injection/indirect injection makes a difference, without glow plugs or with.
There are different versions of these engines.
Good luck.
kj1556
Stoughton, WI
I havent been able to find anything used and the place in TN doesnt answer. I have found a new motor for $4200 plus shipping and tax. Im going to keep looking for a good used one for a few more weeks before I splurge on a new one. On my old motor What is the value on the head and injection because all new ones come complete. The block and crank are bad on mine for sure,
Apogee
Jan 22, 2012
518
Tacoma, WA
I would strongly suggest watching ebay.
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=kubota+v1903&_sacat=0
You will likely find a good one. Shipping will be ~ $350 to get it across the country if necessary.
I would also suggest watching your local Craigslist. Just search for Kubota or Kubota engine rather than the specific model. Why? Because lots of folks don't list them by model number. They just say they have a Kubota or Kabota engine for sale... It will likely take longer but you will eventually find one...
Good luck!
Steve
