Replacing Valve Stem
lmichael
Kubota G2160
Apr 23, 2021
822
422
Rockford IL area
So my G2160 has a leaking valve stem. IDK how but I think after mowing the other night with a couple too many single malts I might have gotten it tangled on something.
Anyway fast as I put air in it comes out around it.
Think it's possible to get a new one and install without fully removing wheel and tire? Maybe just breaking the bead on one side?
Mowbizz
Bx25d
Aug 19, 2021
599
345
Sure! Get a kit that lets you yank out the bad and push in a new one. Did this a couple times on my BX rears that corroded and leaked.
lmichael
Kubota G2160
Apr 23, 2021
822
422
Rockford IL area
So with this kit you don't even need to break the bead of the tire?! BTW this is my left front tire. Are the stems the same front and rear?
Killer Bee
11
Show-Me State
rubber pull through type or metal bolt on?
I would pull the wheel either way. might be a little difficult breaking the bead on a small machine depending how it's supported.
if it's a pull through you should be able to finagle a new stem through with a valve stem puller with just one bead broken. a threaded extension with a pair of pliers will work in a pinch.
if it's a bolt on it might be a little tight getting a hand in there. but if the wheel is off the machine, peeling one side to slide the tire down isn't difficult.
likely pull through. and without looking, gotta be a handful of utoobs to give you a better idea what the process looks like.
these tools are handy, ridges catch on the edge of the rim to help align for straight pull without slipping. a little tire lube or soap helps.
good luck! 🍻
