Replacing bucket pins
Jasper2018
Kubota L3130. LA723 FEL, L3901 HST, LA525, bush hog rotary cutter,
May 25, 2021
49
22
Florida
I have a older L3130 w/L723.
I bought a qsteer adapter that requires the pin removal to get bucket off.
Had one that I had to beat out as rusted in place.
My question is can these pins be found at tractor supply or do I have to go to dealer for this.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,235
1,017
Williamstown Ontario Canada
Your loader is not a L723 but rather a LA723.
The proper pins have a grease passage and need a grease nipple.
At $17.25 each and you need 4, messing around with something else is not a good plan.
If one original pin had to be beat out, sounds like greasing was not being done.
There are two different styles of bucket/attachment but both use the same type of pin.
Dave
Pau7220
Aug 1, 2017
785
278
Scranton, PA
To add to what Dave said... If you use your local dealer, you won't get hit with the overpriced shipping the online orders are being charged.
