Re: Replacement Seat Help
Wolfman - I got the seat and we took the mounting plate off the kubota. I know in the picture it is green - husband used the mower as a painting project.
Anyhow, the plate that mounts the seat to the tractor (green in picture) does not match up to the frame we took off the new seat. Thought we could move the mounting brackets on the frame guiderails using the dimples in the rail as a drill point, but they are there to keep something inside the rails, that keep the two pieces from separating.
Only options I could think of was to drill new holes in the black guiderails or attach another metal mounting plate between the green and black frame.
Thought I would check with you first, as sometimes I overlook the obvious fix or potential problem.
Thanks
