repair manuals
Scott in PA
B7100
Jun 26, 2019
Port Angeles
I have inherited a b7100 grey market Kubota tractor. Serial number starts with 7001. Will a service manual for a North American market B7100 work for my unit?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,246
1,031
Williamstown Ontario Canada
Does your tractor say B7100 on it?
I have a recollection that some B7100 USA tractors had serial numbers like yours.
From Tractordata.com:
The Kubota B7100 was not available in the late 1980s, after that only the hydrostatic was available. Early model B7100 serial numbers began with "B7001", which is the Asian-market model designation.
You can have a non grey tractor and still have a B7001 serial number.
Others with B7100's will clarify this situation.
The kubota Books site has a single volume WSM just for the B7100.
http://kubotabooks.com/AutoIndex/index.php?dir=Tractor Owners Manuals/
Dave
7,135
If it has any english writing on it anywhere it's not a grey.
If the hood says B7100, it's not a grey
Like others have said, a lot of the models of B7100's had serial numbers that start with B7001-XXXXX.
I have one of each B7100-XXXXX, and B7001-XXXXX here and they look the
There is 2 different B7100 manuals on Kubotabooks.com, just pick the three part manual if you have a gear model, or the other if you have a HST.
and if you have an HST model it is 100% not a grey, they didn't make grey HST that I know of. ;)
Scott in PA
B7100
Jun 26, 2019
Port Angeles
There is both English and French on the hood and ignition switch. The ignition switch plate is original, the hour meter is in English and says Nippon Seiki Japan, all in English. Thanks for the info, appreciate the help.
janisre
Kubota, Case IH
Jul 6, 2019
Latvia
KL-500 Re: repair manuals
Hi! I need owners manual for kubota KL-500;
And would like to have a repair manual, too.
Could someone share with some information. Under suggested link here is no such model!! :/
