Removing both FEL and Box Blade while in Garage?
JayOrange
23
New York
So, tractor is currently in a space of ~ 1 car. I'm not sure the best way to remove and store the FEL and box blade. I want to leave just my MMM on for mowing.
I can take the FEL off where the tractor sits. I could always easier drive back up to it to reattach.
However, what about the box blade? The thing is pretty damn heavy. I can't take it off where the tractor sits and then move it. Unless I lay it onto a dolly perhaps? Would that be the best approach?
Or should I try to reverse and turn to remove box blade off to the side? Then pull back forward and reverse straight out of garage now that the box blade is out of the way? This seems like a PITA though.
What is the recommended approached here?
bcp
BX2360
Apr 20, 2011
644
80
SW WA
Without buying or making something, try this.
Reverse into the garage and take off the box blade. Then come in forward, using the loader to move the box blade to its storage place. Then remove the loader.
Bruce
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
If you have enough room you could back straight in and drop the box blade. Then turn around and drop the fel. Anytime you have the box blade on you will probably want the fel on for a counterbalance and possibly for some touch-up grading with the bucket. If you are doing heavy work with the fel, the box blade will make a good balance weight for the fel. Keeping both easily available can be a plus, but at least I would want the fel more accessible.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
With limited covered space I would just leave the box blade outside. As long as PTO and hydraulic powered implements are covered I'm happy.
