Well having been in coal mining for longer than I care to think about the rule stands ANY good grease will work,, my 2360 works hard and she gets her grease anytime between 10 to 20 hours run time, just a couple shots is all it needs, though you might find out that when you start pumping the grease in that you need more than you think cause,, I found at least on my little piggy that everything that needed greased, took a lot more than it should have. Unless of course your dealer did it for you first.
Now if I may impart something about your 2360. On the right side of the deck mat you will see a couple of cut areas in the mat lift the one closest to the middle and you will find a zerbert,, that is for your tram pedals, give that a shot,, right from the get go,, cause thats the shaft that they ride on and if it gets stiff the pedals will not return to center and she will creep on you.
Any good grease I also use the red only because its what I grew up with and I can see it.
ENJOY that bad girl, theres something soothing about a diesel motor over a gas one
..Unless it says HD on the side
