so I posted over a year ago about this engine being low on compression, pulled it, had the block resleeved and the deck milled true, had brand new valves bedded they had to cut the seats slightly and the head milled flat all at a machine shop, checked the valves myself and they vacuum down to 30hg, put it all back together mind you this is like the third time and im having a heck of a time with it, its giving me 140psi on 1, 100 on 2 and 220 on 3, I did add a tiny amount of oil and it bumped it up some but not much, maybe 40 psi each. tried a leak down and it seems like it's leaking between cylinders which I don't understand, I used a brand new kubota gasket and followed the torque sequence and spec for the d950. I'm really just getting fed up with it if im being honest, not sure what to try next 🫤
