Rear work lights
Skillet
Soon GrandL4060, FEL, 72” brush hog, snow blade for now...
Dec 2, 2020
Upstate NY
Apologies if this has been asked or covered prior, search hasn't helped much.
I am adding rear work lights to my Grand L 4060. Ordered the OEM switch which I believe mounts to the right side pillar and has a plug already there?
The lights I'm using are small LEDs mounted where the high mount hazards used to be which I believe already has a wire run from switch and taped to loom?
Question is what are positive/negative wire colors ?
Thanks in advance!
5,137
for my BX23S, there were 3 'bullet' connectors taped to a harness using blue tape. pretty sure this is a Kubota 'standard', well, hope so...
GROUND is the black wire with MALE bullet( exposed pin)
Switched power and live power have FEMALE bullets(hidden socket)
3,331
POWER …is the one that blows the fuse when shorted to Ground. 🤣
(Seriously…. haven’t you got a VOM or other circuit-tester?)
