Rear Turf Tire on L245dt, what on front?
amaurymsa
L245DT with FEL
Aug 27, 2012
39
TOURNAI, BELGIUM
Dear all,
I've the opportunity to buy rear turf tires.
As i have a dt, my concern is to know if i can keep my ag front tires?
Can i use 4 wheel drive?
Thanks
8,173
You should only buy the turf tires if they are the "right" size and ratio for the tractor, and No you can not run turfs on the back and AG's on the front.
If you do you will destroy the 4wd, and don't go with the "well I won't use it", It will get engaged and it will damage it.
amaurymsa
L245DT with FEL
Aug 27, 2012
39
TOURNAI, BELGIUM
Thanks for your input.
Rear turf tires fit perfectly with what it´s requested in the user manual of the 2wd l245 13.6-16.
I've no idea of what is needed on the front as turf tires to use the 4wd... Someone knows?
Thanks...
Envoyé de mon iPhone en utilisant Tapatalk
almondjoy1955
20
Au Gres Michigan
Can I use a different size tire on my 4wd tractor?Proper tire sizing/matching on front wheel assist tractors is a function of insuring that the front axle 'lead" specification is kept within acceptable design and operational limits. Front axle lead (or slippage) is necessary on front wheel assist tractors in order to realize the benefits of front axle tractive assistance. Desired front axle lead is expressed as a positve increase in front axle speed over that of the rear axle, usually in terms of percentage (ideally +1%-+5% for most front wheel assist tractors). Lead percentages outside of this range will lead to problems such as accelerated tire wear, difficult steering, loss of tractive assistance from the front axle as well as increased drive train wear with premature failures. Negative lead (or slippage) will, from the outset, totally negate any potential advantages offered by front wheel assist. Determination of the front axle lead (slippage) for a given tractor is easily determined if one has access to the following information;
Front tire rolling circumference
Rear tire rolling circumference
Front/Rear drive train ratio of the subject tractor
Rolling circumference specifications are available from the tire manufacturer. This is the only tire "specification" that matters for this calculation. Rim size is of no importance at this point.
Drive train ratio is available from the tractor manufacturer.
Calculation for determining front axle lead is as follows; Front Tire rolling circumference x Front/Rear drive train ration %Slippage= Rear Tire rolling circumference Example; Front tire size- 11.2x24 with rolling circumference of 129.6" Rear tire size- 18.4-28 with rolling circumference of 175.9" Tractor Front/Rear ratio= 1.4 129.6 x 1.4 181.44 175.9 = 175.9 = 1.031 (1.031-1) x100 = percentage 1.031-1 = .031 .031 x 100 = +3.1% front lead (Good!) Now, what will occur if we substitute a rear tire size of 18.4x30 having a rolling circumference of 183.5"? 129.6 x 1.4 181.44 183.5 = 183.5 = 0.989 (0.989-1) x100 = percentage .0989-1 = -.011 -.011 x 100 = -1.1% front lead (Notice that this is negative lead meaning the rear axle is over- running the front axle. This is obviously a bad choice of rear tire size for the given front size. In order to use the 18.4x30 tires on this tractor, it would be required as well to install 12.4x24 front tires having a rolling circumference of 137.0". This will result in a lead of +4.52% which is within the desired range of +1.0%-+5.0%. If you have owned a 4wd tractor for any length of time, you have probably noticed that the front tires have a tendency to wear at a higher rate than the rear tires. This is normal. Keep in mind that, because of the design slippage of the front axle, when 4wd is engaged the front axle is, in effect, trying to "outrun" the rear axle. Since the rear axle is supporting 60% of the total tractor weight, the front axle cannot drag the rear axle along with it at its slightly increased speed; therefore the front wheels must be content to slip (or spin). Did you ever watch a teenager "peel out" at a red light? This is exactly what is occurring in the front axle, only at much lower speeds with the associated tire wear being nearly imperceptible. Interesting to note is the fact that the rate of front tire wear decreases as the tread wears. As the tread wears down, rolling circumference is reduced, bringing the front axle lead (slippage) percentage closer to 0%. This serves to illustrate why it is important to be judicial in the use of 4wd, avoiding usage on hard surfaces as much as possible. A related subject is the use of front loaders on front wheel assist tractors. Ideally you want to maintain a load bearing ratio between the front and rear axles of 40%front/60%rear. Asking the front axle to carry more than this share is setting yourself up for expensive repairs down the road. It is important to use appropriate counter-balance on the rear of the tractor to offset the loads that are carried in the loader bucket. Take note that front axle components are generally smaller and of lighter construction than the rear axle. These front axle components were not designed to support 60%, 70% or in some extreme cases up to 90% of the total "load".
If your rear axle is scooting along, just barely contacting the ground now and then, this means the front axle is supporting near 100% of the total weight of the tractor, loader and bucket payload! This is an almost iron-clad guarantee of front axle failure! Be cautious when changing tire sizes. Even the same size from different manufacturers can have a significant impact on front axle leads.
tiredguy
B3030 HSTC,B2781 51" front mounted snowblower,60" MMM
Jan 21, 2010
301
northern lower Michigan
Oh, you Michiganders, how you do go on! (But not one "eh?", so that's nice.) Sadly, your pasting lost the formatting, making the article hard to read. But very valuable information!
Shawn,
another Michigander will simplify what information needed to figure it out,
Using the rolling circumference of the tires you're running now, divide the
front tire circumference by the rear tire circumference and the answer to
that equation is the "ratio" front to rear. Do some research on this part of the forum and you'll see plenty of examples and learn what it all means.
Once you know the ratio you need to keep it at look for tires then always do
the math to see that you come up with the correct ratio and you're good to go.
Al
