My rear “red” tail lights stopped working. Front factory hood lights still come on with the switch. Looks like a pink w/ black stripe wire feeds them. Bulbs tested ok. Anyone got any ideas or have a wiring diagram?
You found a diagram where the color codes actually match! Ha. Any chance I can get a copy? The two I found seems to be for an older model and the cab version. Many of the color codes did not match.Are your grounds good at the bulb sockets?
Do you have 12V out at the headlamp switch?
It's from here- WSM B3350 electrical-min.pdfYou found a diagram where the color codes actually match! Ha. Any chance I can get a copy? The two I found seems to be for an older model and the cab version. Many of the color codes did not match.
