MX6000HSTC factory T-N-T. The side tilt is not centered around the center point of travel. Said another way, there is plenty of travel, but it's mostly in one direction. With a box blade attached, I can tilt one side way up, past where I would ever use it, but the opposite way only goes just past level. At level, the cylinder is nearly completely retracted! There must be a null adjustment or something on these hydraulic valves? I used to work on and adjust Moog valves, but this is completely weird to me. I've never even seen the actual valve bodies. Assume they are in the area below the right side door, which is protected by a steel enclosure.
Can anybody explain to me how to adjust this or provide a reference. Dealer doesn't seem to think it's a big deal, and can't seem to fix it. Looking for information on how these valves work, adjust, and what they look like. Maybe the full service manual WSM might have that kind of information?
As a troubleshooting test I was thinking of swapping the top control hydraulic connections with the side-tilt and see if the problem moves to the top cylinder. Any help would be greatly appreciated. I'm hesitant to start digging in on a fairly new machine and trips to/from the dealer are difficult because I don't have the proper tow vehicle or trailer to move the tractor around, so they have to come get it. Thanks.
