Ram Ecodiesel Oil change question
aaluck
Oct 9, 2019
969
825
Snowdoun, AL
This might be a silly question but... I umpire a lot of baseball in the spring/summer. With that comes a LOT of rain delays. There are times I will sit in my running truck for hours waiting for the weather to clear.
Here is my question. During these spring/summer months my truck is demanding oil changes at about 3-4000 as opposed to the "normal" roughly 10k. Do you think I can just stay on the normal schedule and change it around 10k since about 1/2 (or more) of the engine run hours are me just sitting still?
8,698
I'm definitely no expert, but it has been standard practice for decades to change the engine oil more often (in terms of mileage) if the vehicle runs at idle for extended periods e.g. taxis, police, ambulance, tow trucks, delivery trucks, etc. The widely accepted reasoning is that lower operating temperatures equates to more blow by which equates to more oil contamination. Of course, vehicles from decades ago didn't have the fancy computers in them that can possibly do a much better job of monitoring operating conditions, so changing oil more often was a simple solution to a complex problem.
Oil and filters are cheap (relatively) so pick your poison. If you plan on keeping the vehicle for many years it would be wise to change the oil more often. If you change vehicles fairly regularly then perhaps not.
lynnmor
B2601-1
May 3, 2021
1,545
1,295
Red Lion
If that is a newer diesel truck that is abuse. Yes, follow the OLM or better yet, switch it off.
6,691
I'm far from an expert either. Don't know that much about the DEF systems if so equipped.
I'd also probably stick to what the monitor suggests. Admittedly an uninformed suggestion.
I just recently have gotten so I use the Oil Life Monitor on my gasoline-powered truck.
3,368
You don’t mention the year model or your warranty-status….but long periods of idling will cause your truck to give you an oil-change/service message based upon useage.
If under warranty… I’d change the oil for certain.
If no warranty is involved….it’s your call…but if you are meticulous regarding maintenance, I’d also suggest you change it. Diesels do NOT like to idle for long periods (Forget what you thought because you saw 18-wheelers at truck stops idling for long periods. NOT Applicable to a passenger vehicle.)
Long idling in a modern diesel will kill your very expensive emissions systems, not DEF particularly….but your DPF, your catalytic-converter, your turbo and CCV.
3,450
As much as it pains me to say it, my opinion would be to follow the computers suggested intervals.
I avoid long periods of idling, but thats mostly cause my tail pipe fell off about 10 years ago so it stinks up the cab a wee bit.
I have been on the 10K program since it was new in 06', but if you idle a lot, that "run time" should probably be factored in.
Like suggested above, oil and filters are "cheap insurance". (y)
mikester
M59 TLB
Oct 21, 2017
3,846
2,474
www.divergentstuff.ca
Your ECU is controlled remotely and is programmed by AI to make you pay more money to big business. Oil and filter changes are a scam, stick it to the man and don't believe what your ECU is telling you. Buy meme coin instead using the money you save on oil changes.
RBsingl
Kubota F 2690 72" rear discharge deck, Deere 955
Jul 1, 2022
466
516
Central IL
As other noted, a DPF equipped diesel running at idle/low load for long periods of time is a VERY bad idea.
If your ecodiesel is equipped with a high idle switch/setting then use it but still even at high idle for hours is going to create issues with your emissions system and if that engine has any tendency towards fuel dilution of the oil those long idling periods are going to make it MUCH worse. You definitely need more frequent oil changes and depending upon how much idle time is involved then 3,000 miles is a stretch because you are putting on a lot of hours with not much mileage.
It isn't good for even pre-emissions diesel engines to run at idle/low load for extended periods. If you plan to continue as an umpire (and good for you doing this!!!), then a gas powered vehicle will be a much better choice for your next purchase. Extended idling isn't great for any engine but a gas fueled engine will do pretty well with this in the summer months where it will stay at a good operating temperature for complete combustion with minimal oil dilution.
Rodger
