Hello Everyone!
We recently bought a M135GX and didn't buy it with the radio. I recently picked up a radio and a kubota wire harness to plug into the slot where the radio goes. Here is where I ran into a problem though.. The female plug coming from the tractor does not have the RED and YELLOW Ignition Power and Constant Power (respectively) so where is the radio supposed to get power? Secondly when I ran a direct cable to the battery (just so i get atleast get it working) There was only the ground cable, power antenna cable, FR speaker +, FL speaker +, RR speaker +, and RL speaker +, plus one other one which I am drawing a blank at the moment. The tractor only has 2 front speakers so the 2 wires that are for the back are useless. and when I plug the two front speakers up only the FR one works...What am I doing wrong?! Any help at all would be greatly appreciated! Thank You!
Edit: Also the adapter we bought (the one that you attach the radio wires too then plug into the tractor) had an ignition wire and a constant power wire but they didnt lead to any pins on the female tractor adapter so hooking them up did nothing :/
-Messing
-Messing
