Radiator Fluid Looks Nasty!
kubota.ray76
57
round rock
Howdy y'all. I recently bought a 2012 RTV 1140 (1511 hrs) at auction and I checked the radiator fluid and I was supprised at how brown it is? What would cause it to get that color and what's a good way to flush out the system?
Please look at attached photos
Any ideas or suggestions would be greatly appreciated!
Thanks!
rjcorazza
Mar 9, 2016
778
24
Hyattstown, MD
Suggestions? I generally do not use flushing / cleaning agents, but would make an exception if my coolant looked like that! That’s so bad looking that I would be concerned that the previous owner poured Bars Leak, or some other mechanic in a can sealant in there. Hope it works out for you...
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,189
167
Hardisty, Alberta
The engine has been extremely overheated. Check for errosion of the rad cap seating area, plugged radiator etc. Head gasket and cylinder head failure. check carefully for cylinder scoring
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
Eserv, is overheating a common problem with the RTV's?
I've read several things lately where people were having heat issues. I've wanted one of those but if it can't handle farm work it would be a waste of money.
2,725
I heard that was a problem with the radiator placement - mounted someplace "weird" where it did not get a good airflow....thus overheating problems. Heard some moved it to help with problem
kubota.ray76
57
round rock
I didn't see any erosion on the seating area? I looked at the upper hose and the inside of the hose has a calcium rust build up? I think checking the head gasket and cylinder is above my level of maintenance :( but for the short time I ran it, it started fine and didn't smoke... Im wondering now if I'll have to replace the radiator which looks expensive...
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
I would first start by draining it and flushing with a cleaning agent and water 2 or 3 times and then fill with 50/50 antifreeze and water. Run it maybe it's OK. If it's not you will know soon enough.
eserv
May 27, 2009
2,189
167
Hardisty, Alberta
Overheating can be a problem on some RTV's. The RTV900 is pretty good but if a RTV1140 has a cab on it it likely will overheat if operated in high range.
BruceP
G5200H
Aug 7, 2016
852
369
Richmond, Vermont, USA
I agree with using some kind of flushing-agent (mild acid) to cleanse the system. This will remove many layers of rust and crud from inside the system.
It is OK to use garden-hose to do the initial flushing... but you should use DISTILLED WATER to do the final two flushes.
Antifreeze should ONLY be mixed with DISTILLED WATER.
5,386
2,081
There's not a problem with them overheating. There's a problem with people letting the radiator screens (and radiator fins) get plugged with chaff, dirt, grass, etc. When the fins/screens get plugged, airflow decreases across the core, which then the engine gets hot. Once it gets hot, most people shut them down, let it cool, refill it with water, and start over. Wrong. The filler neck is plastic. It's really easy to deform if they're really overheated (which yours sounds like it was). Then the thermostat is usually damaged if it's original; and won't open properly, sometimes they open too soon, other times they don't open at all, and sometimes they are stuck open. There's a new part number for them but I can't say why it's a new number, they look the same. Maybe they changed the kind of wax that's used inside of 'em. Dunno.
Same thing for the BX series. Screen and radiator get plugged, people blame the "design" and cuss the little tractor, when there ain't anything wrong other than the person who's not doing the maintenance. See it all the time. "Well I clean that blankety-blank screen all the time".....yep...but never clean the radiator; and that's what's plugged. Screen's clean. Folks I ain't making this stuff up. Happens WAY too often. I really shouldn't care since I get paid to work on them. But at the same time, I want people to be pleased with their stuff-which means if I can help prevent big expensive repair bills and the associated dissatisfaction, I will try.
