quick hitch tilts to the right during operation
setdhuk
quick hitch
May 18, 2026
Mississippi
why does my QH10 quick hitch tilt to the right during operation? i constantly have to monitor whatever implement i am using to keep it level. frustrating!
Blue2Orange
BX2380 with LA344S & QH05. SB1051. SG0554. BB1248. RB0560, Vassar dirt bucket
Apr 3, 2025
431
301
Bayview Township
Image? Assuming tilting off axis clockwise relative to the tractor v. just shifting to the right? And when not loaded with an implement sits level relative to the tractor?
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
279
673
wisconsin
are you running hydraulic tilt??
3,093
Do you have rear remote hydraulics and a hydraulic tilt cylinder installed? If so the system is leaking and letting the cylinder length vary.
To test set the level you want, the disconnect both hoses from the valve using the quick disconnects (that I assume you have installed). If no drift then you can hook them back and prove that the drift starts again.
There is a double pilot operated valve that can be installed to allow you to adjust the position but then it magically locks it in place until you intentionally move it again.
setdhuk
quick hitch
May 18, 2026
Mississippi
thank you!
SDT
Apr 15, 2018
3,684
1,408
it tilts with or without implement. I don't have a pic.
Given available information, it would appear that you need to adjust the leveling assembly on the right side upper lift arm to level the lift arms.
11,077
If your running hydraulic tilt and it's moving on it's own then you have an issue with that system.
Does you tilt cylinder have a load check on it?
JonM
Nov 29, 2024
279
673
wisconsin
some systems will bleed down when the tractor is off. my top link is hydraulic and does this sometimes especially if it sits for a few hours. my remedy is to start the tractor and cycle the cylinder a few times to get the fluid pressurized then its fine. running it through its range of motion a few times ensures pressure is there.
