Quick Attach (FEL) & Bucket Question
wendol
L3800 HST
Feb 5, 2014
194
40
North Tx
I'm considering converting my LA524 loader to the QA set-up.
Once I install the OEM QA, can I use any QA style bucket?
Thanks for any/all help!!!
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
Yes. Or any SSQA attachment that your tractor can handle.
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
437
41
Red Springs, NC
Yes and you can cut the factor ears off your current bucket buy a SSQA plate to weld on it. Good as new. I did this on my LA463. (Same style loader as yours just earlier version) Look around your area I found a place in Denton NC that makes all kinds of SSQA pieces and they sell the plates for 50.00!!! I bought three for that price. Dad's L3800 has the LA524 and now we can share buckets and pallet forks.
6,607
Be careful with SSQA buckets, as most are designed for Skid Steers, and they can be too heavy.
And most SSQA implements will be heavy and require more hydraulic flow or capacity then your tractor can put out. ;)
85 Sovereign
L4701 HST
May 3, 2017
30
Northern Virginia
Good point!
Although it may "fit," it's not a guarantee that it'll work like you intended. Just take weights into consideration when you're choosing attachments and you'll be fine.
On a side note, there is a difference between SSQA, the old John Deere QA, and larger QA connections. Generally speaking, the SSQA (Skid Steer Quick Attach) and Universal Quick Attach are synonymous.
