question on my BX brakes
4,062
Ok I like so many others have at one time or another managed to forget to release the parking brake and it supprised me that little bugger would pull through and keep on going,,, but I digress,,, how would a person re adjust the parking brake on the BX? I have been under my little orange, and am some what befuddled as to how to adjusted it,, and no I dont have the shop manual
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
I guess my first question would be, "What is wrong and why does it need to be adjusted"?
Is the brake pedal going to the floor when the pedal is depressed?
Are you unable to get it to release?
Does the locking lever on the left floorboard not work or catch at the wrong place?
Do you want the parking brake to anchor the tractor so it won't move under any circumstances? (Probably not good for the HST.)
The parking brake is likely a very small, light-duty shoe-type arrangement that is simply for holding the tractor in place from some outside influence. For instance, my 400 gallon water wagon will move the tractor around if the water is sloshing or if on a slope.
One hint that it is a small part is that the tractor can overcome it easily as you point out. Maybe Kubota made it that way to save the HST.
My wife puts the parking brake on each time she uses it and I don't. That often causes me to drive away with the brake on. The HST whines a bit so that is the alert.
Usually Kubota uses turnbuckles for adjustments so locating one of those on the linkage would most likely be the adjustment point. On the other hand, there may not be an adjustment.
4,062
All very valid questions, I have a bunch of grand kids and I want to make sure the little orange piggy donent m ove if they are playing around and it will move slightly if I push hard on her when it off,, And you know kids. I have one GD that has driven that little tractor around the world several times,,lol
GWD
Jan 8, 2010
792
17
Northern California
Ah...a safety issue.
I can't imagine the BX moving too far with the engine off. You could try blocking the rear tires with a couple of 5 foot, 4x4 fence posts.
That would probably stop the BX from any travel - even when running - if the parking brake was also on. You could try it but don't burn up the HST in an attempt to get it to move.
It is more work but when the safety of the grandkids is a factor there is no reason to cut corners.
