QA Post Hole Auger for B2650
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
The content of this post has been edited to remove any possible offensive material. Sorry for the post.
Thank an offended member.
despling
B2301-TLB, BH70, LA435 w/QA
Nov 29, 2019
12
Tucson
I have the Landpride HD25 auger motor mounted to a SSQA and using a 9” auger. I am using this on a B2301 with no issues, except that I have rocky soil, so I have to go a little slower or I end up binding up. The LP HD25 is a good motor, but I also considered the Danuser PD6 hydraulic motor. I can’t really give any advice on the Danuser. It looks well made, but the dealer convinced me to stick with the Landpride line for most of my attachments. Not sure if that helps.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
If I remember correctly, Land Pride makes a QA one like you are wanting. Check them out.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
BigG
Sep 14, 2018
1,951
773
West Central,FL
Looking at the Landpride augers I think that I wood look at the the side of the bucket style. With the smaller tractor you might use a quick attach plate and place a plate perpendicular to the QA and you could increase the lifting height if needed.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
BigG
Sep 14, 2018
1,951
773
West Central,FL
Thanks for the link. It just needs to spin a little faster. :)
I am shooting for 50RPM. The mixer will be happy with anything above 30RPM.
If I understand correctly you are wanting to use the motor to run a concrete mixer? If this is correct and you buy the SSQA why not mount the motor on one side and the drum on the other and use a gear and chain to produce the desired RPM?
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
BigG
Sep 14, 2018
1,951
773
West Central,FL
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
BigG
Sep 14, 2018
1,951
773
West Central,FL
It shows the 2500 unit runs on a minimum of 7 gpm and the B2650 makes 8.7. I am not arguing I was trying to figure out how to read the info correctly. I know enough to know I do not know enough.
8,477
8.7 GPM is total flow
3.7 GPM is for steering
5 GPM for all other systems
So a b2650 Max could maybe power a 5 GPM min motor.
I say "could maybe" because there are other factors involved that could limit the flow down even more. ;)
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
