Pto won’t stay engaged
Edwardo
10
Auburn, AL
I was bush hogging the other day and had to switch off the Pto to dismount the tractor (MX5400 HST). When I went to engage the Pto , it would not stay engaged. I tried several times but no luck. If I held the switch to on, it would run but as soon as I let go it would switch off. Any ideas?
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
120
47
NH
Seat safety switch?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,568
1,810
Near Lancaster, PA, USA
Just a guess but I'd check the PTO switch itself. Sounds like it is making contact as long as you're holding it. How difficult would it be to access the switch - or a plug in the harness?
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
248
249
Amsterdam, NY
Just a though...
Check in and around the switch / lever for dirt, debris - leaf, grass clipping etc. May be just enough dirt to act like a spring and only make contact when compressed. Hopefully it's something simple.
MOOTS
MX6000
Jun 27, 2019
2,157
2,667
Canton, Georgia
Are you pushing down and twisting to the right to lock?
