PTO Troubles
ChuckB2
M5040D
Mar 13, 2017
Hanahan, SC
I have an M5040DT. The pto seems to slow down when running a bush hog and I get into heavy brush.
Any suggetions?
7,757
ChuckB2
M5040D
Mar 13, 2017
Hanahan, SC
Wolfman, Thank you for your reply.
Tachometer is on the way.
I will post some better information soon.
I have talked with a Kubota dealer who indicated that it might be a problem with the pressure relief valve.
Any thoughts on that?
kuboman
725
Does the cutter have a slip clutch on it? Does tractor rpm slow down too? Your tractor should have pto speed readout on the dash, what is it telling you?
ChuckB2
M5040D
Mar 13, 2017
Hanahan, SC
Thank you both for the help. Sometimes all it takes is someone else making you think thru the problem.
PTO speed does not slow down and yes the implement has a slip cluth on it.
The clutch disc on the bushhog needs replacing.
But on a goodnote...I now have a new Tachometer.
