PTO Shaft Trimming
GrumpyFarmer
3,449
So far all my implements that run off PTO came with shaft all ready set up from dealer. Recently I picked up a chipper and I suspect I will need to fit the PTO shaft myself. What is the general consensus on what tool to shorten a PTO shaft? Hacksaw, cut off wheel, saw all, portable bandsaw, other? Which way and why would be helpful. Please advise. Thank you in advance.
4,707
Anything that works. It ain't important what tool you use as long as it cuts clean.
FTG-05
Jul 21, 2013
286
121
TN
AND is cut to the correct length.
Too short: Twist the PTO shafts = $$
Too Long: Damage the gearbox = $$$$ -or- Damage the tractor = $$$$$$$$$
5,422
whatever you're comfortable operating ! Be sure to use a NEW blade and 'deburr' the freshly cut edges BEFORE trying to use it. Use a thin coating of light oil or 'rustcheck', slide PTO shafts together/apart several times, THEN try it for real.....
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,967
1,626
WestTn/NoMs
My order:
cut off wheel (Makita makes good ones - HF are horrible but will work)
portable band saw
sawsall
..anything else..
hacksaw (I'd put oxyacet torch above this)
5,422
do NOT use an oxy-acet torch ! There's no way anyone can make a perfect ,straight, clean cut. You NEED a PRECISE cut.......
If you have a sawzall/recip saw, buy a QUALITY metal cutting lade and it'll be cut in 5 minutes or less.
B737
LX3310
Jun 9, 2019
2,024
2,202
lol omg
it does not have to be PRECISE, it doesn't even need to be cut straight! its a freaking keyed PTO shaft. hack, debur, clean, grease done. lets not turn this into rocket science from your armchair.
RalphVa
738
320
Charlottesville
Main thing is to cut it about 1 inch shorter than directions say. Otherwise, it's too difficult to get the thing crooked to get it onto the PTO shaft.
I used a sawsall for both the plastic cover and the metal PTO parts.
7,770
Cut equal lengths off male and female side of the shaft!
ctfjr
L3800HST
Dec 7, 2009
1,977
2,523
central ct
I've used a hacksaw, sawzall, abrasive saw and portable bandsaw. For me the sawzall was the winner and as GreenvilleJay mentioned, a good blade helps. The hacksaw was too much work compared to the sawzall and the portable bandsaw was too heavy. I didn't like the 'fine' mess the abrasive saw left.
