In an earlier post {PTO hookup Question) I was having a problem aligning the PTO shaft with my OLD bush hog splines. I took the shaft off, used rust remover, used a metal brush wheel to remove more rust, sanded the new kubota PTO shaft to remove paint and still the bush hog connection would only slide on about half way.
So, I went out to my old 1963 MF35 and easily slid the connector on with no problem.
I finally had a good idea-measure the size!! I found out that the new Kubota shaft size is 1 3/8" while my old MF shaft is 1 5/16". So, that makes me think that my bush hog female receiver is 1/5/16" alsoNo way that will fit the Kubota with a 1/16" difference.
So, am I correct that the Kubota PTO shaft is indeed 1 3/8"??
Is there such a thing as a PTO reducer/adapter?
Any suggestions?
Thanks again
Vann
Any suggestions?
Thanks again
Vann
